[ QUOTE ]
ensig said:
The emitter pulled from a star will have lower Tj compared to a true emitter. Remember reading this from one of the thread.
However, for your application you should stick with the star, it makes life alot easier.
And 2x2 copper sheet is not massive by any means. It depends on how long you keep it on and how much current. Are you planning of DD, LM317, CC5W it?
I have a similar setup with a 2"x3" aluminum plate for my car Lux3T @ 700mA it will cause heating problem when I leave it on for 30 minutes.
Copper is only good for surface heat xfer. I recommend going with aluminum
[/ QUOTE ]
while 2" x 2" is not massive it will do. would suggest going with Al. copper will soak up the heat but won't let it go as good.
below is estimate for Luxeon Star on the minimum recommended heatsink size based upon AB05. Junction Temp = 120C, Ambient Temp = 60C(140F), 350mA, 3.42Vf, R Theta = 20 based upon DS23
if you're going to use a flat horizontal heatsink the minimum is:
2.75 sq. in. of exposed surface area.
if your ambient temp is 55C(131F) minimum is:
1.079 sq. in.
on a previous post, i did it for a Luxeon III Star on the minimum recommended heatsink size based upon AB05. Junction Temp = 120C, Ambient Temp = 27C(80.6F), 1000mA, 3.9Vf R Theta = 17 based upon DS46
12 sq. in. of exposed surface area.
if interested send me what star you're using, your highest estimated ambient temp and we'll see what we get.
just a guide. for more info see AB05.
