LZC vs XM-L RGBW
meyerovb
Comparing the XM-L Color to the LedEngin LZC RGBW. I'm powering it through a wall adapter, not batteries, so power usage is not a concern, however heat dissipation is a concern, so not sure how much bigger a heat sink the LZC would require. I'm mainly concerned with brightness. As far as I can tell at 1amp, although it takes significantly more power, the LZC will deliver much brighter results than the XM-L. Not sure though since the XM-L Color is so much newer. Am I incorrect?
