ElectronGuru
New to the CPF community?, click here to register
ThreadsCustom SF Hosts
Custom SF Parts
Custom SF Upgrades
SF Modification Service
Moddoo Triple
Moddoo M2-50 (you are here)
Custom SF Parts
Custom SF Upgrades
Moddoo Triple
Intro
Kilolumen LED setups require a lot of power. But to work and keep working, their energy must be controlled and then directed. Presenting the first SST/50 installed in an M2 bezel, a pocket sized mini turbo head, compatible with 6P's, C2's, and Z2's. A CPF community production: engineering by Moddoo, testing by Sgt. LED
Specifics
The LED- 5+ peak amps to an SST-50 LED
- Direct drive, single cell operation
- Choice of cool or neutral (see options)
- Cool are 5700K, SST-50-W57S-F21-GJ201 (highest output, select tint)
- Neutral are 4500K, SSR-50-W45S-R21-GJ401 (highest output, and best tint)
- Exceeds the amperate rating of our McClicky kit and most other switches
- use our Zero Resistance Kit for reliable performance
The Head
- Deep/steep reflector for maximum focus with a semi compact head
- Fully integrated heatsink for continuous operation
- Shock and vibration tolerant materials and components
- Heavy duty positive contact spring
- Solid brass negative contact ring
- Shock proof materials, components, and design
- Suitable for use in weapon mounted lights
- mil-spec wire, teflon insulated
Restrictions
- Do not run primary CR123's or any IMR or any 26mm cell
- Use only with 18650/2600 cells. This cell only:
Cautions
- Do not leave unattended while running
- This light creates excessive heat.
- This light may cause eye damage
- This light may burn the skin at close range.
- This light may cause combustibles to ignite
- This light is not a toy, keep away from children
Ordering
Please follow these steps:1) Click here
2) Click Add to Basket
3) Click View Basket
4) Select shipping
5) Check out
Special note: this is a high demand item, available in small batches, on a first come, first basis. Purchases are limited to one per customer per batch.
Please reply or PM with any questions
:devil:
