M2Xvn
jmpaul320
CT, USA
Re: M2Xvn - High Quality Budget Thrower
Olight M2Xvn XPG2 PDTc drivervn2
Sony vtc
889@ turn on
842@ 30 sec
616 high
442 mid
130 low
39 low 2
2 firefly
Throw - 385,000 lux
wow!!
Capolini
Banned
Valley Forge, Pa.
Sony vtc
889@ turn on
842@ 30 sec
616 high
442 mid
130 low
39 low 2
2 firefly
Throw - 385,000 lux
wow!!
:cool::cool::cool: .......NEW KING for its class dethroning the:
Eagle Tac M25C2vn XPG2 PDT
Samsung 20r
816@ turn on
783@ 30 sec
Throw - 343,000 lux
Capolini
Banned
Valley Forge, Pa.
JUSTIN OR VINH! DO YOU NEED THE VN2 DRIVER TO GET THE ABOVE POSTED NUMBERS?? IF SO WHAT WOULD THE DECREASE BE IF ANY WITH STOCK DRIVER DD SINGLE MODE?
THANKS,,,,,,,,,,,,,,,,,,,,CAPOLINI
jmpaul320
CT, USA
the single mode/direct drive should be close to the same... drivervn2 is direct drive on high.. the only difference would be internal resistance of the stock vs drivervn electronics... probably a negligible difference
Capolini
Banned
Valley Forge, Pa.
Thanks Justin. I am getting this light thanks to Vinhs Fairness, Trust and Patience! :) I am getting Single Mode DD just like his M2Xvn U3 Brother. This will be a great test for the water tower. I think it will make it.
385Kcd=1241M/1357Yds. I am thinking and hoping the DD/SINGLE MODE will push it another 82yds.!
THE TOWER IS 1438 YDS. AWAY. THAT EQUATES TO 433Kcd/1316m/1439yds. 1 yard to spare!
THIS WAS MY FIRST TESTING SITE. Four of my torches made it easily. TK61vn V1, XSearcherVN, K40vn and OSTS TN31mb. The only one that was NOT verified in terms of testing was the K40vn. It was known to be ~400Kcd. This test proved that mine is
433Kcd+:thumbsup:
Capolini
Banned
Valley Forge, Pa.
Re: M2Xvn?
I just got One of these[link below] for the M2Xvn XPG2 PDTc version.
Scroll down 3 levels to the First RED BATTERY!
http://www.imrbatteries.com/brands/AWT.html
There was not ANY battery on HKJ's comparator that had a better Voltage sag, [ie less of a voltage sag] To the AWT IMR 18650 2500mAh 35A version.
That was comparing IMR 2500mAh versions to Efest, K'power, LG HE2/HE4,Samsung 25R and Sony VTC5 2600mAh. Samsung and Sony were very close.May be a Sony Cell? It also Exceeded all of them except Sony VTC5[2600mAh] at all the different currents ending at 2.8v. ie best run times,,even if it was slight!
This is relatively new battery. AWT IMR 18650 3000mAh 35A. I guess I will find out if the quality and performance are as good as its 2500mAh version! :cool:
Alex1234
Bear Delaware
Re: M2Xvn?
Let me know. the 4.50 price tag is nice but is a bit fishy. Thats almost to good to be true and it out preforms the top brands
Capolini
Banned
Valley Forge, Pa.
Re: M2Xvn?
??? lol!! You must be looking at the wrong battery! It cost $9.50! I put this in op........>>>>> Scroll down 3 levels to the First RED BATTERY! AWT IMR 18650 3000mAh 35A.
Alex1234
Bear Delaware
Ops never mind i looked at the yellow battery. Im looking at my phone walking in the full sun in epcot. Can barly see it
Alex1234
Bear Delaware
Only flat tops. ?? They dont work in my single cell vinh modded eagle tacs
scs
ET reverse polarity protection design requires button top cells.
Capolini
Banned
Valley Forge, Pa.
All I can tell you is what I told you! They work in my M2X[spring in head],they work in my E'Tac modded lights that I mention. If they don't work in yours,,,,,,I am not sure why!
Capolini
Banned
Valley Forge, Pa.
Guess what,these FLAT TOPS are raised,,that is why they work! I am not making this up!
Just a little further elaboration gentlemen!
-I have been using K'Power IMR 2500mAh Flat tops for my M2Xvn for over 5 months
-I am using Efest IMR 3100mAh Flat tops for my TX25C2vn for 6 months.
-I have been using NCR18650BD 3200mAh Flat Tops for my S200C2vn for over 1 year.
If you look at these threads,especially the S200C2vn you will notice a comprehensive discussion about FT or NO FT! ;)
EDIT: YES,E'tac does state that you can not use flat tops.As myself and others have proven they can be used[raised FT]. E'Tac doesn't want you to use them which is understandable.
Capolini
Banned
Valley Forge, Pa.
TRIFECTA POSTS: THE MOST ENTERTAINING OF THE THREE!
IT WAS JUST AFTER MIDNIGHT LAST NIGHT. I HAD JUST FALLEN ASLEEP. I LIVE IN A SECOND STORY CONDO. I HEAR SOME RUCKUS AND CARRYING ON OUTSIDE MY WINDOW. I LOOK UP HARVEST LANE ~100YDS./91M AND I SEE SEVERAL PEOPLE NEAR THE POOL.THE POOL IS NOT OPEN FOR 2 MORE WEEKS. I SCURRY INTO THE DINING ROOM WHERE "CAPO'S" MAIN ARSENAL IS LOCATED. MY 3 X 18650 & 4 X 18650 LIGHTS DO NOT HAVE THEIR BATTERIES IN THEM. I GRAB A VERY CAPABLE 1 X 18650.....THE M2Xvn "U3" DD/SINGLE MODE LASER!
I QUICKLY RETURN TO THE WINDOW AND THE "PUNKS" ARE STILL LAUGHING AND CARRYING ON.I TURN THE LIGHT ON AND SEE THEY ARE INSIDE THE FENCE OF THE POOL. THE M2Xvn SEEMS TO STUN AND SHOCK THEM!:eek:I HEAR ONE OF THE PUNKS SAY,"WHAT THE HELL IS THAT"!! THEY ALL START TO JUMP OVER THE FENCE TO EXIT THE POOL AND RUN TOWARDS THEIR CAR. MEANWHILE THE M2Xvn IS ZEROED IN ON THEM!:cool:ONCE THE PUNKS START TO EXIT I GIVE THEM ~ 5 OR 6 SECOND REPRIEVE! I DID NOT WANT TO BLIND THE DRIVER WITH A HEAD ON SHOT AND HAVE HIM CRASH INTO SOME PARKED CARS! WHEN THEY APPROACHED MY WINDOW AND ARE BASICALLY RIGHT IN FRONT OF ME[SIDE BLAST] I BLASTED THEM AGAIN, LIGHTING UP THE ENTIRE CAR FOR SEVERAL MORE SECONDS UNTIL THEY LEFT THE COMPLEX!!!
I DON'T THINK THEY WILL BE BACK! IF THEY ARE STUPID ENOUGH TO COME BACK I WILL TAKE THE TIME TO THROW MY BATTERY CARRIER IN FOR MY TK61vn V4!
EDIT: I FOUND OUT THAT THE COVER WAS TAKEN OF 2 DAYS AGO! THAT EXPLAINS MORE WHY THOSE IMBECILES WERE INSIDE THE POOL!THEY MUST LIKE "WINTER WATER"[UNTREATED BEFORE SUMMER SEASON].
I SAW MY NEIGHBOR CHUCK THIS MORNING. HE IS A LOCAL COP WHO LIVES AT THE END OF THE COMPLEX. I GAVE HIM THE SUCCINCT VERSION. HE SAID, "GOOD JOB BOB"!
CONCLUSION: DRUNK PUNKS INVADING PRIVATE PROPERTY. SOLUTION: PROBLEM ERADICATED BY THE M2XVN!:twothumbs
THE BEST THING ABOUT THIS IS I DID NOT HAVE TO SAY ONE WORD AND I DID IT FROM THE COMFORT OF MY BEDROOM!!!:laughing:
engineeringmatt09
california
Awesome story!!! I've been liking the DD U3 pdtc option. I think it will have to be my first large reflector thrower, 2nd will be a tk61 u4 pdtc!!!
charlieplanb
No cursing,no swearing ,no hooting and hollering,no drinking,no breaking things .
Sounds to me it was just some kids having fun.
Not, PUNKS, IMBECILES , and DRUNK PUNKS ,,, Yeah,good job bob. You showed those lawbreakers.
jmpaul320
CT, USA
interesting story , nice to have a good flashlight when needed capo :)
If they didn't live in your condo complex I would also tell the local police - they could be arrested for trespassing if they come back.
