I'm sold on it, I just need to figure out an easy way to bore my surefire C2 to accept them. I was thinking of trying out a small brake cylinder hone from an autoshop, they seem well suited to the task.
I'll call up lighthound tomorrow and see if they can check one in a C2. If not I'm going to check firsthand, I'll be ordering a single imr18650 along with a wf139, a protected 17670 and some imr16340s. If the 18650 isn't feasable in a c2 I can always find something else to use it in, like a leef body later on :) I've heard of folks with 18mm batteries in M3's and M4's, so hopefully it'll be all good :)
I posted in another thread about using a 4/3A cell. The module works between 1v-5.5v as per Malkoff website. These cells are 1.2v nimh and have between 3800 and 4500 mah. You just have to make sure that you order the correct size as they come in 17mm and 18mm sizes. You can check them out here.
17mm= http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=4665
18mm= http://www.batteryspace.com/index.asp?PageAction=VIEWPROD&ProdID=3240
