piesoup
Hello all
Just to let you know what I am using before I get into the question... The lathe is 8 x 14 with 1.75hp motor. A 4" 3 jaw chuck and a vertical slide.
Now I have dove quite a bit of 'normal' turning but have come up against a brick wall with this one!
What I am trying to do... 50mm stock of aluminium with 4 20mm holes on a 28.5mm PCD. ie. 90degrees apart.
Now, can I put my piece if ali in the vertical slide and a centre drill in the lathe chuck. Align the work with the vert slide and drill a centering hole in corect place. Then move the carrige back, replace the centre drill with a larger drill bit, drill to the correct depth. Carry on until I am nearly at 20mm, then put a 20mm endmill in the chuck. Ending up with a flat bottomed 20mm hole. Then repeat for the other 3 holes.
Is that feasable??? Or has anyone got any beter ideas!! I only have a lathe by the way, no milling machine unfortunately. I can buy a 4 jaw independent chuck if it helps.
Any ideas, advice will be greatly appreciated.
Thanks in advance!
Andrew
Thanks in advance!
Andrew
