Matjazz
- Joined
- Dec 3, 2009
- Messages
- 94
I guess I don't have to stress how expensive caving lights (waterproof, separate flood and spot) are. I decided to make one my self. At first it was going to use aluminum project box. I had it pretty much figured out and drawn but then I wanted something "proper" and drew some 3D models for CNC and a simpler model for lathe. After I found out how much CNC would cost and lost patience with a friend that has lathe I went back to the project box headlamp.
I used some ideas that I got designing "proper" housings and figured out that I have all the pieces for a prototype.
So I drilled some holes in Hammond project box
Placed on-of-on switch and a cable gland
Then I got too excited to take pictures. Few hours later the light lit up
The original lid is replaced with 5mm Lexan. Both leds are Cree XM-L. Flood is driven with a 3 mode 1A buck/boost driver. Spot is driven with a 2A customizable linear driver and is equipped with Leila RS optic from Ledil. Spoot and flood can't shine at the same time.
Next day I made Helmet mount and switch shield
I got some experience and ideas for improvements. Perhaps I’ll make it an “open source” headlamp with all parts listed and plans/drawings available. I had it in a cave and it performs well:twothumbs. I think this could be made in to a decent caving lamp. I have some ideas for battery canister and will report back if successful.
