Here is my second Mag build the first was a 2D mag this one is a 2C.
2C form factor is easier to grip IMO.
Parts/mods:
Wicked HS color eh?:p
Not my best soldering job and I cut the reflector with a hacksaw!!:thumbsdow
Used some AA NIMH for testing with make shift paper battery holder:ohgeez:
Spring is too large for the AA cells so used a quarter as a washer.
Beamshots to come later....:duh2:
Pros:
Cons:
BEAMSHOTS
AMBIENT LIGHT
2C P7 DSVNI 1.2amp on C-cell alkaline(left) .........................................................2D P7 DSXOJ 2.5amp 3xNIMH cells (right)
Nitecore D10 Q5 1AA NIMH........................................................................................Surefire 6P w/ Q5 1amp drop-in (18650 cell)
The 2C again....................................................................................................................the 2D again
The D10 again...........................................................................................................................The SF 18650 XRE Q5 again
Ajay:wave:
Parts/mods:
- Mag 2c black
- Seoul P7 DSVNI (5350K?) from LiteMania
- Anodized MagC heatsink from LiteMania
- 17mm 1000mAh 5-Mode with Mode-Memory Circuit Board for Cree XR-E Emitters (0.9~4.5V Input) from DX
- Cut down stock reflector
- Stock switch
- Cut down spring a few mm, stock sprint too stiff.
Pros:
- Runs great on Alkaline 2C cells draws 1.5amp at tail and gives about 1.2 at LED. Not sure how since this is supposed to be a 1amp board.
- Can be upgraded in the future for more amps (brightness) easily.:xyxgun:
- Underdriven P7 runs cool, had to use some aluminum foil to make heatsink fit nice and tight in the mag body.
- Nice neutral/warm beam color.
- Circuit capable of running on just one cell...I checked(0.9v)
- Can run on 2 AA cells with a paper battery sleeve in a pinch.
Cons:
- The heatsink pedestal is too long (high) so the mag head must be screwed out far for it to focus for maximum throw. I had to add another o-ring to the head to make turning the head harder....I don't want the head to unscrew too easily over time.
- The circuit board inductor runs really hot and another IC on the board runs pretty hot too. I did test 30 minute run times and the board did not burn out....at least for now:eek:
- Too many modes, 5 in all. High, med, low, strobe & SOS
BEAMSHOTS
AMBIENT LIGHT
Ajay:wave:
