Mag question
gcbryan
Seattle,WA
Why are there so many Mag's used as hosts?
What do you do about the switch mid-body?
Are the lens naturally watertight for diving?
There must be some reason to use a Mag as a host?
Are Mags ever modified as hand-held dive lights as opposed to cannister?
Relatively Cheap, Solid Metal Tubing, local off the shelf availability
Cutting the tube down or switch to a IP68 switch
Not really, though it's a simple swap and extra o-ring
Need more?
Yes, either or... canister to me is about power and duration...
I built my first mag mod for diving when the TerraLux bulb first came out using info from pcmus.com as a starting point, 6 months later I found CPF ;-)
Because they are cheap and easy to mod and have a good sized head that takes a MR16 sized reflector/ optic/drop in.
Cut the switch section out.
Yes. But not to any real depth
Yes. See answer #1
Yes.
