maxhawk
I've built a Mag85 using Fivemega's 9AA->D adapter with the stock switch and potted WA1185. I didn't get instaflash, but probably after operating about 3-4 minutes the bulb blew. I replaced it with a second bulb and it worked fine for the next few weeks with usage of minimal run-time.
So the other day I recharged the batteries. They sat off the charger for atleast a day, and after operating the light for only a minute or two, I notice that it had developed an orange hot-spot. I turned it off and found the bulb to be a frosted white color instead of clear. I'm sure it's going to blow if I run it much longer.
What am I doing wrong? Isn't 9 AA's the standard configuration for the WA1185? I checked the voltage hot off the charger and it was 12.3 volts or so, which I found quite normal for NiMH. I'm using Maha 2500mAh cells charged with a Triton charger at a rate of 1.0A.
Do I need to switch to CBP1650's? Let the batteries sit longer before using the light?
Thanks for your suggestions.
