I was getting ready to order some stuff from kaidomain. I initially wanted an aluminum reflector to run a 2d ROP. Thing is, I have a spare 3d mag I am not doing anything with and a bunch of eneloops.
So now I want to try to make a mag85. I am planning on getting a g4 bi pin socket from kaidomain. They sell a bulb (KD880U) which has the following specs: [email protected]
will this be ok to run on 9AA eneloops or will the light be a lot dimmer than running it on a welch allen 1185 bulb?
the 5 pack bulbs are priced well, but I just don't want to order it if its not going to be over driven to produce the high lumens.
Should I just pick up the gr pi bin socket and look for another g4 bulb? if so what bulb other than the welch 1185 would you recommend, maybe something a little less expensive. I know the mag85 specifically calls for a welch 1185, but looking for other options to run on 9aa eneloops.
EDIT: also, do they make g4 bulbs that would run good on a 6AA ROP type setup? Just wondering if there is a good g4 alternative to a pelican big D
