Mag-Lite® Rechargeable Flashlight System™
I had a problem with my MagCharger and finally got some help from Ginseng, (thanks).
I thought I would post some of the pictures that go along with the instructions for disassembly.
link
Pic 01
Obviously, this is where you start.
Pic 03
Remove the reflector and bulb.
Pic 04
Unscrew the head. Right hand threads, quite fine like the threads in the tail cap. There was corrosion in the threads and it took considerable force to unscrew the head. I had to clamp the battery tube in a vice using soft wood to cushion the tube. The discoloration on the threads is a copper based anti-seize. I can unscrew the head by hand now.
Pic 06
End of battery tube, charging rings and center contact (positive) spring. The spring is just pushed into the center hole. I found corrosion on the spring and bottom of the hole.
Pic 07
Spring removed.
Pic 08
Positive charging ring removed. The ring just slips off. Note the hole under the charging ring. This is the contact for the positive ring. It looks like a wire with an insolating spacer but it is actually the end of a diode.
Pic 09
Positive charge ring diode removed. It just pulls out of the hole. Note the spring on the end of the diode. I found corrosion in the diode hole so if your MagCharger is not charging the batteries, this may be one place to look. Again anti-seize on the diode spring.
Pic 05
The head assembly. Remove the switch cover.
Pic 16
Contact end of the switch assembly.
Pic 11
Depress the switch and slide the switch assembly out of the head assembly.
Pic 14
All of the parts together. I did not disassemble the switch assembly. In testing, I did not find anything wrong with the switch so I did not tamper with it. The switch assembly is riveted and crimped together. I am sure you could get it apart but getting it back together may be another mater.
Hope this helps.
link
Pic 01
Pic 03
Pic 04
Pic 06
Pic 07
Spring removed.
Pic 08
Pic 09
Pic 05
Pic 16
Pic 11
Pic 14
Hope this helps.
