Why isn't the magnetic control ring type functionality more popular and demanded?
I don't have a control ring light, but here's what I think of the functionality (with no actual experience)...
The magnetic control ring user interface is like the gesture functionality on my phone. A multi-mode clicky is like setting the time on my clock going in one direction; if you pass over the time you intended, you start over and cycle.
With a magnetic control ring type of interface, I can immediately get where I want, and in either direction (higher or lower).
With a magnetic control ring I can adjust the brightness levels real time. As I'm walking and have the light pointed down, I can be on lower power. When I need more distance, I can select higher power. I can go back and forth real easy and fast, and very intuitive.
For EDC, I simply see clicky and twisties as archaic technology, though will still have a niche.
So why aren't we seeing control ring interfaces from every mainstream manufacturer?
