Last week the Eurobike show was on in Friedrichshafen / Germany.
I visited the Reelite booth and learned about a new light system that doesn't need spoke magnets but works just from being close to the rotating rim. And the prinicple is similar to the Magnic Light, I was told. It's the first time that I heard of Magnic Light and I took a note to check this out later.
Now the thing I've seen at the Reelite booth was a little plastic case, roughly 1" by 3" and rather slim, with a red LED in it. When held near a rotating rim, the LED slowly lit up. It wasn't very bright and the slow startup suggested a capacitor got charged in there.
The box was partially translucent for the LED to shine through, and I spotted a copper winding inside. Sure I was curious to learn how exactly it has been made inside but staff wasn't prepared to explain this in detail.
Today I googled Magnic Light and was surprised how much discussion it has generated - and no detailed explanation of how it works, yet. It got me hooked and I did some experiments of my own, trying to confirm my idea how it might work.
I have a motor-driven bicycle front wheel in a test stand near my electronic workbench, perfekt for this test. I brought an inductor (a salvaged mains transformer primary) close to the rim, the oscilloscope showing the open-circuit voltage at the inductor terminals.
I then played with strong rare-earth magnets near the inductor and around the rim.
I tried various positions for the magnets and the inductor, different inductor cores, magnets inside the inductor. I settled on an arrangement with an I-core in the inductor, a disc magnet at the end of the core, the magnet close to the rim. And yes, I measured an AC waveform at the inductor terminals, its frequency related to the wheel speed, it's amplitude higher with the assembly closer to the rim. Looks like this concept works !
I observed that magnets were more difficult to hold by hand, the closer they got to the rim: At one point of the rim, the joining point, it pulled so strongly on the magnets, that it was hard to prevent touching the rim. Well, this joint appeared to have a piece of steel inside (confirmed on stationary wheel). The rest of the rim made the magnets vibrate slightly.
The inductor waveform was close to sinusodial and my optimum arrangement yielded around 300mVpp. Once per rotation, a rather large pulse (1.5Vpp) occured.
Next I took a look at the frequency of the large pulse and the steady sinusodial signal. The large pulse was obviously one per rotation of the wheel. But what could determine the sinusodial signal's frequency ?
I set the wheel to 96 rpm (=1.6 Hz and period T=0.625s), the signal has a period of 17.5ms, that is 35.7 full signal periods per rotation. Familiar number ? Well, the wheel has 36 spokes ! (Allow for some inaccurracy of my analog scope).
Conclusion: The spoke nipples are slightly disturbing the magnetic field, creating the AC signal that I'm seeing. Without spoke nipples and rim joint, no output. So this works like a hammond organ, the rim with nipples is the tonewheel !
Now I believe that the Magnic Light (and the new Reelight thing I have seen) is much more refined than what I built from bits and pieces that I had around. But will it really extract enough energy to power an LED ? Isn't the strong force on the magnet a problem for the mounting ? And does it rely on the rim joint or on the nipples or on both to be there ?
Could it be the Magnic Light is working in a different way ?
I hope we soon see the first samples being sold !
