[ QUOTE ]
Brock said:
Two more things I thought of.
First a solar panel usually puts out a slightly higher voltage so if it does get shaded a bit it is still above the rated voltage.
I did only test it for about 2 min, I wonder if it starts pulling more power as it gets going? Or I wonder if since the batteries weren’t dead it didn’t put as much power in to them. I will have to meter more of them with different batteries to be sure, and for a longer time.
[/ QUOTE ]
Spot on on the second point. So I broke down and cut the cord. It does indeed start low and 'all over the place' in a series of two or so second pulses averaging maybe 80 mA per cell? and changing in duty cycle as more cells are brought on line. However, about two minutes into it it 'changes into high gear', 850 mA for four on high, 280 mA for four on low. Makes sense now.
The 'need more voltage than 12' is because the cell voltage isn't constant, it goes up a bit with more sun. It's my understanding that the rating is 'full sun' current (1000 Watts to the square meter incident) at the *nominal* output voltage for the panel (even if it's reading higher). "Specsmanship" doesn't seem to be routine in this industry? However, if shaded even a little bit, they crash. The cell in shadow becomes an open, current drops to near zero. A real problem on boats where it's not possible to aim them so they're mounted flat and have to deal with shadows from the rigging when the sun is overhead (the only time they'll work well anyway).
BTW, other interesting numbers for these are 13% or so maximum efficiency (makes the panel power to size make sense) and anywhere from 42 to about 50% of the total daylight hours times ratings for expected output by a well aimed panel at the NY/SF type latitudes (37 or so degrees). Other 'experts' say to design around 5 hours output at full power for good days. Meaning my new 24 Watt panel should produce something like 100 to 125 Watt hours per day. More or less. FWIW it has 36 cells (33 or so seems to be the absolute minimum for serious 12 panels, you need to count, panels with less can be chronically under voltage to recharge lead acid batteries).
I still want to know how many AA NiMHs my Maha 401 being powered by my brand new 24 Watt panel can charge in a typical day.....
Doug Owen
