maha 777 plus 2
Brock
Green Bay, WI USA
Ok, I just got my maha 777 plus 2. So I thought I would start yet another thread about it. I got it on ebay for $80.
My favorite feature is the mA in during charge. I use NiMH batteries all around the house and I had been just charging them every week not know how much was really used. For example I have a baby monitor hooked up to 4 9000mA D cells. I just charge them once a week no matter what. I know it draws about 25mA and runs 24/7 so in a week it should use about 4000 mA. Well now I am going to find out. I also have a couple of LED night lights that run on 4AA cells, again I can guess how much power they are using over the week, but now I will finally know how far I am discharging them.
I am sure I will find more things to like or are odd as time goes on.
What other thing do people like / dislike about it, any tricks I should know?
Brock,
I got mine only last week. I really have nothing to compare it to. It's my first store-bought charger. I have no complaints at all. It's easy to use and does the job.
I tried it on a protected Li-Ion cell, and it worked flawlessly. However, the battery started to make a whistling sound -- around 5KHz to 10KHz. The sound would go away when I moved the battery. I think it was the battery and not the charger.
I had no holder for the Li-Ion cell so I wedged it in a slit piece of radiator hose. I slipped in a piece of metal to contact the positive terminal and a spring for the negative. A strip of duct tape held the whole thing together. I guess you could call that a trick.
I, too, would like to hear about other people's tricks.
Paul
I know the LiIon charges at a lower rate, but are the stop points differnt? I gues what would it do if you set it to Li and charged Ni in it? It shut off charging a 6AA pack, it got to warm. So I was thinking of trying the same pack on Li, but for some reason I think that might not be a good idea.
PaulW,
I don't know what type of Li-Ion cell you use but have a look at LitFuse style cool... /ubbthreads/images/graemlins/buttrock.gif
Vince.
Brock -- I also have thought about using the Li setting for NiMH batteries. But note that the 777+2 looks at voltages in multiples of 3.6, not 1.2, on the Li setting. So I would guess it would work only for 3, 6, 9, or 12 cells. After some thought, I see no advantage to do it and perhaps some over- or under-charging issuess. -- Regarding any use of the NiMH or NiCad setting for Li-Ion batteries (just in case someone misinterprets what we're talking about), it is a very dangerous idea from what I read. When I charge my Li-Ion I always check and double-check the display to be sure it says "Li."
Vince -- I am using a 168a that came with my McGizmo "Xenergy Moddity." I think you are referring to my make-shift way of connecting to the cell. Yep, Litfuse's setup is much better than mine. Someday I'll build or buy something for my little charger.
Paul
Yup, charging Li with Ni setting is a BAD idea. I would also think there would be overcharge or undercharge issues using the LI setting for Ni bat's.
I've had a 777+][ for over a year, now. I chargec Ni cells at ~800mA*h and Li-ion cells at a variable rate starting around 800mA*h as well, but then tapering off. I've used it to charge 2.8A*h NiCd banks, 10A*h Li-ion banks, and a variety of Ni and Li packs for my many amateur radios. I've been very happy with it.
I guess I don't have the 180 minute shutoff problem that's been reported, elsewhere.
I do have the noise on charging Li-ion cells. I just assumed that the SMPS that forms the current regulator in the charger is changing through a range of duty cycles as the charge state progresses and that is what is causing the tone to change pitch. It bugs me a little, but then a turned on TV bugs me.
