661randyg
hi all, this is my first post here. im not perfect with writeing skills so please use this info for your good and try not to pick it apart too much.
its getting very frustrating reading in all types of reviews (wethier batteries or flashlights) about this lower amp rated battery runs my flashlight longer than this higher rated one. and also when the person is upset that thier p7 controler is only drawing 1.5 to 2 amps when all along the problem may be your battery is old(getting worn out), not fully charged, or to low a mahr rateing.
wether your powering a dc motor or a flashlight, 90% of the time when you run a higher rated battery (even agm, lead acid, nimh etc.) you will get more watts of power used which will shorten battery cycle. for example, useing my trust fire ssc p7 f15 with a 1800mah 18650 batt. ill get about 2.3 amps, but with a 2400 bat i can get closer to 3amps(= 3000milamps) also meaning i get more light. with the 2400 bat some have even complained thier light gets hotter.
this is normal and a good thing if you want more lumans on high. this is a nice thing about haveing a low mid high light is turning it on high for a few minutes when playing or searching then going back to mid or low for work.
the easyest way to test this and also check how good your battery is with it fully charged. with you meter on amps with the back cap off touch one lead to threads on case and other the to battery in your light. with a newer battery your not that interested in voltage while testing , just amperage. of course you never want to discharge it too deep or wont take a charge. you could manuly bring it back up but thats another post.
if anyone feels they can explain this better knock yourself out. as it says in the bible in proverbs a multitude of counslers brings wisdom. i have had a love of batterys since i was around 5yrs old and even learned on my own how to charge a battery from another one. also ive done just about everything your not suposed to do like blowing up batteries and also hosed off acid with my water hose on a guys face who installed his charged batteries wrong on his truck. but thats how to learn under controlled expermenting. also the love of lights is included since 5.
its truly amazing how far lights have come in the last 10 years. i hope this will help everyone get the most enjoyment from thier lights. btw im waiting for my first ssc-50 , the aurora sh-40 33615 Aurora SH-40 Luminus SST-50 5-Mode 1000-Lumen Memory 33615 Aurora SH-40 Luminus SST-50 5-Mode 1000-Lumen Memory
ATTENTION MODERATOR, IM NOT SURE WHICH POST TO PUT THIS IN AS IT APPLIES TO ALL POST. IF YOU FEEL PEOPLE WILL BENIFIT FROM IT CAN YOU PUT IT SO ALL FORMS WILL SEE IT. THANKS AND HAVE A NICE DAY
