AlexGT
Hi guys!
Just wanted to let you in on a little mod I made. If you have a burned out PT Rage textured lamp assembly, you can dremel out the reflector to fit a Minimag, the OD is exactly the same as the minimag and the result is a more smooth beam that can be focused.
Don't expect a SF quality beam, but is far better than the stock reflector IMO. /ubbthreads/images/graemlins/wink.gif
The whole procedure takes about 20 mins. with a dremel.
Hope you find it interesting.
C ya!
AlexGT
C ya!
AlexGT
