kelmo
I received it last Thursday, the mailman just delivered it as I was leaving for a 4 day camping trip. I had planned on taking an E2e as my handheld so I popped on the Malkoff and off I went. It is smaller than the KX bezels, both in length and girth. Mated to an E2e body makes for a very nice pocket rocket. The finish is very similar to the black anodizing that Surefire uses now, ie easy to scuff. This thing is a beast! It crushed my friends 6PX Pro, the 200 lumen version. It puts out a fat cone of light with a intense corona. The tint is not bad by LED standards. Mine was a faint green and color rendition out in the forest was no problem as the shear amount of light compensated for the LED ghosting effect. The beam I would estimate spread out to a 45 degree arc. Anything within 50 meters was lit up. It was bright enough that if you shined the light at your feet the glare produced is annoying. If you want a room sweeper this will do the trick. I dressed mine out with a E2O tube and a Z68 switch. If you use a Z57 this makes for one very pocketable light.
If your a Malkoff junkie you need this!
kelmo
kelmo
