jimmy1970
yeah, that's precisely the point.
You know - from the gazillion posts I started on that matter - I like Malkoff and SF but I am not blind or biased. I am at times frustrated with it. The single mode bothers me, it needs dual mode. 123 cells are nice but are expensive, even the cheapest ones like BatteryStation are not all that cheap. To get 'guilt-free lumens', you have to use Li-Ion cells, and protected ones at that. They work fine but will cut off suddenly, leaving you in the dark.
With M60, bring spares with your EDC... At least 1 set of spares and I carry 2 (two) for this reason. M60 will go through your Li-Ion cells in *no time at all*.
The only reason I got Malkoff M60 is because it pumps out 230+ lumens, no lite of its size/runtime can do that. If M60 "Low" halfs the lumens, why should I have to put up with all the limitations of the Malkoff/SF platform, I might as well get a dual mode lite like EagleTac. It can do all that and more, and be slimmer.
The good thing about Surefire / M60 is it seems bullet-proof, well-made, idiot-proof and a lacks features, which might be a good thing. As software developers say, "It's not a bug, it's a feature".
It must the "Surefire Way".
Running Malkoff on 2x18500 is "Okay" but not impressive runtime. As discussed before, I am losing runtime vs primaries, but furthermore, it appears that running it in shorts bursts (vs. one long 2+ hour run) it gets worse runtime.
Really, look at things in perspective. What lite gets similar lumens/runtime in that size.
As I said before, pick 2 out of 3: Runtime, lumens, size. My Malkoff 3D is just as bright and will run for a long time but not so good for EDC.
I cannot wait until I get quality 18650 cells, as AW promised 2500 mAh protected cells (vs. 2200 mAh now) and then I might be happy with that platform and heck, might abandon the 18500 cells entirely.
But I disgress. Any Malkoff is an excellent lite but it's also an excellent example of a single-purpose lite that doesn't work well in all situations. Try reading with it for example.
Does anyone have the Malkoff M60WLF yet? I have one on the way. Maybe I'm the first one. Please report if you have received this drop in and give us a mini review - would be greatly appreciated.
James...
