Does Malkoff make any P60 drop-ins that have multiple levels?
That sounds good. Thanks for the info.No, but if you can get your hands on a dual-level swithc ring when they are in stock on the site, they make for a great light. It is actually my preferred UI in my "bump in the night" light. It is one (BRIGHT) stage, with an available low if needed....but that I can never accidently turn on the wrong level.
GDuP Malkoff? :D
It sure is for me. I'm waiting for my recently ordered first p60 host to arrive from Hong Kong and, in the meantime, am searching for a neutral drop in with a "buttery" smooth beam like you described the M61 to have, but I also really want it to have 3 modes with memory as well, (and also can't really afford to drop $69 on it right now). But some day I'm sure I will get one though.
Thanks for the recommendation. Don't want to derail the thread any further but I will look around for more info on those.well, Thrunite's 1.5A XP-G would probably be perfect...their 1A is no slouch either. both are approx $35. the 1.5A is in my C2 w/ a sharper reflector as i mentioned earlier and it's output and capability is right up there w/ most of my high output lights. the 1A is nice because the low and middle modes are capable of covering a wide range of applications whereas the 1.5A pill's low and mid modes are hardly discernable. not sure why they did it that way.
