vadimax
But why not a single weapon light has a TIR lens that would produce a very narrow spot in the center of the beam. That would replace the need of laser beam in the dark. Just place that hot spot on a target and you know where your bullets go (more or less). Of course, that would require weapon light centering, but why not if that will obsolete the need to aim through barely visible sight.
The only problem I see so far -- sophistication of the lens. Most likely it will require double layer construction to avoid/minimize spectral artifacts of the aiming hot spot.
