MB 300D headlamps
Random Guy
I have a 1984 Mercedes Benz 300D, with E code headlamps. Underneath the certification marks on the headlamps, there are arrows that point to the nearest side of the car. Facing the front of the car, the right hand (driver's side) headlamp has an arrow pointing to the right side of the car. The left hand (passenger side) headlamp has an arrow pointing to the left side of the car. My question is, are these headlamps for countries with right hand traffic or left hand traffic? I have a crude drawing that may help. If you need it, just send me an email or PM. Thanks in advance.
The meaning of the arrow is totally dependent on which function mark it's near. An arrow near the [A] mark indicates the side of the car for which the parking lamp is approved. This kind of arrow always points outboard (away from the centerline of the car) when the device is properly installed, so if the arrow points to the left as you view it, it's for the right front or left rear of the car; this applies to all turn signals, parking lights, brake lights, reflectors, basically any function that is not a headlamp. An arrow on a side-mounted device (turn signal repeater, side marker light) points towards the front of the car when the device is properly installed. The possibilities are:
⇐ (device is for right front, left rear, or left side mounting)
⇒ (device is for left front, right rear, or right side mounting)
No arrow means the device is suitable for use on either side of wherever it's destined to go (front, side, rear).
An arrow near a low beam headlamp function marking such as [CR], [HCR], [HC/R], [HC], [DC] or [DCR] indicates the side of the road for which the headlamp is intended. Possibilities are:
No arrow (the headlamp is for use on the right side of the road)
⇒ (the headlamp is for use on the left side of the road)
⇔ (the headlamp can be adjusted for use on the left or right side of the road)
There's more detail on Stern's lens markings page.
OK, good. I saw the other thread about traffic handedness of headlamps, and was worried I had LHT headlamps here in RHT America.
