McC2S, how much current?
abuhannibal
Israel
Will the McC2S handle enough current to be used with a direct-drive P7 or MC-E? I am thinking of using one with my new Milkyspit roomsweeper (Leef C-C 2x18500 body, Milky-modded C2 head with an MC-E.)
The plan would be to only hit the max output for a few seconds at a time, say half a minute at most.
Thanks!
-- Bob
Please ask on the McGizmo forum since Don designed and knows this stuff.
Then please post your answer here so we all know.
Can you give even a rough estimate for the McE2s and the McC2s?
I'd be more worried about the surface-mount resistor eating itself on low beam, honestly.
The resistors used are 1206 and in most cases we use two resistors to get the desired resistance. Each resistor has 1/2 the total power loss across the switch. A standard 1206 resistor is rated for 0.25W. Together two resistors is ~0.5W.
Industry standard practice is to derate resistors by 1/2 of the specified wattage. This puts the two resistors at a safe 0.25W.
Power across the two resistors if you know the current is:
Current^2 * Resistance = Watts.
A 60 ohm switch uses two 120 resistors. (use 60 ohms in the equation).
Working backwards re-arranging the formula we compute the max current as:
0.25W / 60 ohms = max_current^2 = 64mA
For other resistor values you will have to plug them into the equations to determine the max current.
Wayne
