I am confused on something and requesting your assistance for the following;
We selected a 5mm led for our design having 6000-8000mcd value at 30 beam angle. Using the calculator here; http://led.linear1.org/lumen.wiz the results are between 231 lumen to 308 lumen for 180leds placed on the board.
However, I am comparing another 5mm led having 2900-8280mcd value at 60 beam angle and using the same calculator the lumen value is between 439 to 1255lm for 180leds which is more than 3 times better than previous leds.
Our clients are complaning about the brightness of the unit and If I select the bigger beam angle with smaller mcd value leds, it seems there will be more light produced from the board.
What do you think? Is that calculations correct above?
Thanks in advance;
Thanks in advance;
