MWClint
Putting an XP-E in the Sapphire is much easier to do than modding it to fit a High CRI P4 as there's no boring of the head. The XP-E
is much smaller.
I started with a 5mm nichia Arc pill and ground off the top portion of the
5mm led. Then Drilled a hole down thru it. Wired it up thru the hollowed
led...siliconed the XP-E in place and then trimmed the corners, so it wont
short inside the sapphire head. no metal heatsinking is required at these current levels.
cut and drilled 5mm led. i use kynar wire.(used for wire wrapping circuits)
another view before setting the xp-e in silicone glue.
overall size is the same. This keeps the xpe up front in the sapphire head
for maximum output. If u can tell, it's now glued in place.
nicely centered..and allows the use of the original oring around the 5mm led
to hold the pill in place.
couple shots of xpe installed in the head
couple beam shots. all flood, no hotspot.
neutral white color is :)
I do prefer the High CRI P4 and it will stay in the sapphire, it has a little more red in the beam
which probably why the CRI is higher. nothing wrong with the neutral white xpe though..
it's a pretty easy mod.
is much smaller.
