tnuckels
Is it just my imagination, or is the silvered orange peel material that is affixed (sprayed on?) to the inside of the bezel of the McR-XX reflectors quite delicate?
I purchased a McR-18 a little while back for my aging LongBow Micra. This was a great upgrade that really helped the light achieve much better throw compared to the stock optics, and a wonderfully crafted piece of hardware in its own right.
My next thought was to see if this reflector might improve the beam on my Peak Caribbean, but I needed to remove a small amount of material from the final aluminum stair-step on the outside of the reflector in order for it to fit, diameter wise. Using a piece of 300+grit sandpaper, I carefully made my way around the circumference, removing the material a little at a time. When I thought I had removed enough material, I blew the dust out of the inside of the reflector, and then carefully wiped it out with my shirttail. Inspecting my work I was much chagrin to see, not a beautiful shinny reflector, but one marred with yellowish green blotches. The more I wiped, the worse the blotches got.
Looking back, I probably should have blown the reflector out more thoroughly with my compressor, then used a clean cloth, one that wasn't possibly exposed to the dust from my material removal, to wipe out the interior. My other thought, however, was WOW … it didn't take much to totally ruin this reflector, and I hope others don't run into this problem modifying them to fit their lights. Silly me, I just assumed that the shinny surface was something hard and durable, like the rest of the reflector.
After quite a bit of effort, I was able to remove all the coating from the reflector's inside by using successively finer and finer grit sandpapers, then using a multitude of finer and finer polishes I was able to bring the interior surface to an acceptable sheen, so that the reflector was not a complete waste. Not as good as it was, but not bound for the dust bin either.
Just call me careless, but I'm a bit reluctant to repeat this lesson at $20 a pop, and I post this here, not as criticism, as I think these are wonderful little creations, but simply as a heads up for others not to repeat my folly.
