koala
Hello cpfers,
As usual, programming my atmel microcontroller do pwm then I thought of something regarding the peak current running through the Luxeon. Sorry, I don't have a scope /ubbthreads/images/graemlins/frown.gif.
Consider the highly sophisticated circuit above /ubbthreads/images/graemlins/naughty.gif put it in words, that's direct drive(do not implement!).
The white Luxeon in this circuit has a vf of 3.6v, direct driven with 4.2v.
There's no current limiting resistor so let the resistance of the circuit be 0.1ohm. The current going through the Luxeon when the switch is toggled will be...
0.1ohm = (4.2-3.6) / ?Amp /ubbthreads/images/graemlins/confused.gif
6Amps? Direct driven? I might be wrong here...
So, back to the question. If I got really fast fingers /ubbthreads/images/graemlins/ooo.gif that can toggle the switch on and off(PWM) at 1khz will the peak current be 6Amps?
Vince.
Vince.
