Meet Wizard C2 Pro Max!
ArmyTek
Berlin, Germany
Flagship product in multi flashlight lineup — brightness like never before!
________________________________________________________________________________________________________________________________________________________
Impressive features of Wizard C2 Pro Max
Flashlight for those who need not just bright, but astonishing light.
Wizard C2 Pro Max is the newest model of the demanded all over the world multifunctional Armytek Wizard lineup with record light output of 4000 lumens.
The 3 in 1 multi flashlight for outdoor activities, hobbies and work is comparable in power to a projector.
The main advantages of the flashlight are wide beam angles 110°:150° and an even smoother transition between hotspot and side spill.
Combined with extended runtimes thanks to the larger capacity 21700 Li-Ion battery, these features make use on the head as comfortable as possible.
Multi flashlight 3 in 1
Headlamp
• Simple one-hand operation, reliable headmount.
• The flashlight is easily installed, removed and 180° rotatable in the mount.
• Quick-release rubber ring provides additional fixation.
Every Day Carry
• Compact design.
• Convenient side button.
• Strong built-in tail magnet androbust removable steel clip.
• Special matt anti-abrasive finish without rough knurling.
Bicycle light
• Body made from durable and lightweight aircraft-grade aluminium.
• Improved shock resistance.• Constant light without flickering.
• New springs for better battery and driver protection.
• Quick-release mount in the set.
Advantages of the new generation flashlight
• Maximum LED efficiency: wide new generation LED ensures better light efficiency with impressive output of 4000 lumens;
• New optical system and TIR-lense:transmits more lumens, provides comfortable wide beam with 150° spill;
• New magnetic charger: 21700 Li-Ion 5000 mAh battery is charged in the shortest time possible (5 h 20 min);
• Extended set: 21700 Li-Ion 5000 mAh battery, battery adapter for use of any 18650 batteries, magnetic USB charger and ABM-01 bike mount.
Bright light for bright results
Set records with Wizard C2 Pro Max.
Place an order today and be the first to receive the new product!
https://www.armytek.com/flashlights/models/wizard/armytek-wizard-c2-pro-max-magnet-usb/
Thank you for choosing Armytek!
