I would like to use the Micro Star 100 (1 led) assemblies for my deck project. I have a hardwood deck with a 55' perimeter wood handrail at 36", posts spaced 54" to 58" apart (on center), and railing infill with 10 horizontal runs of 1/8" SS cable. I have seen various illumination pictures of the MicroStar track lights, but think the Model 100 might give a cleaner installation look. All I want to do is light up the cables in a downlight fashion by drilling a 1/4" hole and inserting the fixture into the bottom of the handrail. I will use similar spacing for the stairs, which will probably give me a lit walkway, too. What would you recommend for spacing?
After viewing the product images and specs, it just dawned on me that this looks like a Nichia 312BS epoxied into a wood post protector sleeve. I don't need the grommet, and I have seen the sleeves sell between $0.39 and $1.35 apiece, and the Nichia 310DS or 510DS for $0.85 shipped. Or go with the Radio Shack 5mm. If this is the case, maybe I could make my own assemblies for $2 to $3 each. Is there an advantage to 3mm or 5mm, if both fit into the sleeve? I think the 1/4" OD sleeves support a 3/16" cable.
Thank you,
Geordon
Thank you,
Geordon
