ryback64
Hi,
I am looking for middle range throw flashlight.
I have big hands.
About 200 and 300 meters throw if possible.
Lumintop PK30 or Olight S65 are my first choice with Sanyo Eneloop or Duracell Active Charge in AA and Maha Powerex MH-C9000.
I do not own a NIMH and Li-Ion charger.
I do not own AA NIMH an Li-ion batteries.
Checklist:
____I will be mail-ordering or buying online, so this doesn't matter.
2) Budget: An easy question, but you may change your mind after answering the rest! :-)
____Less than $150.
3) Format:
____I want a flashlight.
4) Flashlight-specific format/size:
____Holster carry.
____Big enough to need its own travel caseJ.
5) Emitter/Light source:
____LED (known for efficiency, longevity, and compactness)
6) Manufacturer:
____I want to buy a light from a traditional mass producing manufacturer that is ready to go out of the box.
7) What battery type do you want to use?
____I intend to use rechargeable nickel chemistry (NiCad, NiMH, NiZn)
____I intend to use rechargeable lithium (li-ion) 18650 chemistry.
8) How much genuine out the front (OTF) light do you want/need? Sometimes you can have too much light (trying to read up close up with a 100 lumen light is impossible).
____I want to illuminate my entire backyard or a campsite (150-300 lumens).
____I want to illuminate an entire field, the neighbor's front yard several houses down, impress my friends and neighbors, etc. (300-700 lumens).
9) Throw vs. Flood: At what distance will you be most likely to use this light? Select all that apply.
____Less than 5 yards/meters (looking for something inside a dark shed/garage/basement)
____5-20 yards/meters (check out a noise in the backyard)
10) Runtime: Not over-inflated manufacturer runtime claims, but usable brightness measured from first activation to 50% with new batteries (Measured on maximum output).
____90-120 minutes (Runtime is moderately important, but still not critical)
____3 hours + (I critically need this light to run on max for extended periods in between battery changes/charges).
11) Durability/Usage: Generally the old phrase “you get what you pay for” is very accurate for flashlights.
____Critical (Survival).
12) Switch Type and location (choose all that apply):
____I want a body mounted switch (near the head, like on a Maglite).
____I want a tail mounted switch (found on the majority of today’s high end lights).
____I want a selector ring.
14)Material/Finish/Coating
____Anodized Aluminum – either type II or III (Hard Anodized) (Aluminum, specifically HA, is the most common material/finish for today’s flashlights).
____Stainless steel (durable, but much heavier than aluminum)
____Titanium (durable and nearly as lightweight as aluminum, but can be moderately to significantly more expensive).
15) Special Needs/extras: Is there anything else you want or need that hasn't been mentioned? Select any below.
____I have big hands so the flashlight must be easy holding.
Thanks
I have big hands.
Checklist:
____Less than $150.
3) Format:
____Holster carry.
6) Manufacturer:
Thanks
