Minimag UV modules?
Aux
Central Florida
Have a 2AA minimag that I was thinking of converting to LED. Does anyone sell a UV / NUV module for this application?
The near UV LEDs that I've seen appear to run with about 3.2 volts at 20 ma. Fresh alkaline cells should put you close to that, and the LED can be direct mounted into the bi-pin lamp holes (observing polarity). Check the amps with a multimeter.
Daniel
