Mixing CR2 and CR123 batteries; yes, or no?
AllenMcB
I've got a 2 D cell mag light clone that needs some juicing up. I'm wanting to do this with what I have laying about in the shop.
I've tried matching other batteries to the length of 2 D cells. Three CR123s aren't long enough, four are too long. Three C cells are too long. I don't have any AA adapters.
On a whim, I put two lithium CR2 batteries in line with two lithium CR123s. Almost an exact match in length. Different brands, but both lithium, both 3v.
But then............ I did a search in these forums for the words "mixing batteries". Lots of cautions about mixing chemistries, voltages, used and new, etc. Lots of notes on how this is a bad idea.
So, I'm down to two questions:
1. Can CR2 and CR123 be mixed, two each, since they/re both lithium and both 3v?
2. If the answer to 1. is "no", anyone know of an easy juice-up for a 2 D cell mag light, or am I looking at ordering the 3 AA adapters?
Thanks in advance....
The answer is a big no!
From memory the CR2s have a lower capacity, will thus discharge quicker than the CR123, and then probably start reverse charging. This is a very bad thing, the result will be as if you tried to recharge a lithium primary.
3 AA adaptors are one option, or if you can find any two Li-Ions in D cell format are also possible.
As indicated by the previous poster:
DO NOT MIX BATTERIES! An explosion could occur.
Never mix batteries, even same size and different charge state is dangerous. using different capacities in a mix is a guarantee to get a nice :poof:.
3 Sub-C's should fit a 2D, but maybe you need to trim the spring. 2xD = 60mmx2= 120 mm. Sub-C = 42mm x3 = 126 mm
