Hello i modded my TN31 by dedoming the XML led.
Measurements : original 1meter lux : 76.000lux 2meter lux :24.000 x 4 = 96.000lux
Measurements : dedomed 1meter lux : 90.000lux 2meter lux :37.000 x 4 = 148.000lux 4meter lux : 11000 x 16 = 176.000lux
question 1 : Can it be right that my measurements at 2meter are so much higher than at 1meter? ( 65% in case of the dedomed one)
This was the good part of modding.
Now the bad part : after i dedomed the XML , the 2 lowest settings of the TN31 dont work anymore (led does not light up) setting 3 and higher works like before (strobe also)???
Hooked up a 3watt cree xre instead of the xml , and the 2 lowest settings work fine (also the higher settings) tested up to setting 4 did not tried higher because of danger of frying the xre.
question 2 : Can dedoming change the Vin of the led?
Thanks Marc
Thanks Marc
