modder required
Metatron
Banned
perths lightening swamp
To build a 14 watt welsh allyn drop in for my D mag tri bored and housing a battery pack rated at 15.6 volts. the switch is an AW soft start.
cheers
steve
I'm no ican guy but this seems pretty easy. Pick up a tri-bored D mag from someone in the B/S/T. I know member Jesus Hernandez does them. I think you just pop the stock switch out at replace it with AW's switch and put a bulb in. You may need an aluminum reflector and glass lens. I have no idea how hot that thing gets. Hope that helps.
cheers
steve
Looks like these are the bits Steve already has. I'm not sure I understand the question.
Norm
Hi Norm, yes, those are the parts i already have, what i need is a drop in with a 14w WA HID globe.:thumbsup:
Gotcha now Steve, fairly sure you will only need to use the standard switch with the Welch Allyn HID . Is this what you had in mind?
http://flashlightnews.org/story1834.shtml
Hope you get it sorted it will be a lovely light if you do.
Cheers Norm
you need to get the end lathed to the right dimm's so the balast fits?
what the dimm's are exactly i dont know?
any ideas anyone?????
