Fallingwater
A small question on the Photon Freedom: if I were to modify it to accept two CR2032 cells instead of two CR2016s (this would require some hardware hacking, of course, due to the different thickness of the cells), would it work properly? I'm thinking as it's electronically regulated it should avoid extreme overdrive and quick death of the LED (which is what would happen if one were to feed a direct-driven knockoff with two CR2032s) while achieving significantly longer runtimes.
