Sold/Expired Moddoolar Cell Tubes and P60 interfaces now available
Moddoo
Minnesota
Hello Guys, We would like to announce the Moddoolar Cell Tube
(click on pics to purchase)
The second part of the new Moddoolar flashlight system, this flashlight body is available in 5 popular battery lengths. Compatible with all Moddoolar as well as SureFire® P, C, Z, and most M series bezels (with optional interface) and tailcaps.
Moddoolar Cell Tubes offer:
Forward compatiblity with all Moddoolar heads
Backward compatiblity with all SufireFire P, C, and Z heads (with optional interface)
Universal tailcap compatibility
Battery retention lip (keeps cells in place when changing heads)
Battery bumper (helps protect cells from impact events)
Double tail O rings
Rounded edges for durability
Anti reflective (semi gloss) finish
Tough 2 mil type III (HA) anodize coating in black or natural gray
Ready for use with 1 light holders and brackets
Compatible with
TorchLAB Moddoolar Flashlight System
SureFire® Z41 tail threads
SureFire® Z44 bezel threads (with optional interface)
Options
Length / Model
TL34 (34mm) fits: 1x16340, 1x18350, 1xCR123
TL50 (50mm) fits: 1x18500, 1x14500, 1xAA (14500 or AA use sleeve)
TL65 (65mm) fits: 1x17650, 1x18650, 2x16340, 2x18350
TL100 (100mm) fits: 2x17500, 2x18500, 3x16340, 3x18350, 3x CR123, 2x 14500, 2x AA (14500 or AA use sleeve)
TL130 (130mm) fits: 2x17650, 2x18650, 4x16340, 4x18350
Compatibility
By itself, the Moddoolar Cell Tube is ready to use with all Moddoolar heads.
Add an optional P60 Interface and gain:
Compatibility with Surefire Z44 and similar bezels
Compatibility with popular P60 sized LED and incan lamps and drop-ins
Interface adjustability eliminates bezel/body gap common with modern drop-ins
O-ring position engages threads before reaching the seal, for easy bezel use
One cool feature of the Cell tubes used with the P60 interface is this:
If a P60 LED drop in is used, this combination eliminates the common bezel/body gap that occurs on traditional lights.
Pictured below is the same drop in installed in both lights.
Hello Tom,
Would it be possible to reveal some information concerning the forthcoming bezel (e.g. number of levels, switching/operating, emitter, tint, throw/flood, .... something at least:naughty:)?
Filip
Any idea on when the 1x18650/2x18350-size will be available??
Need for 'Pocket'.
Regards, Chuck
Hey Guys,
We are machining more Cell Tubes all weekend.
Trying hard to get these back in stock ASAP.
Good to hear! Would these work with malkoff's hound dog or wild cat heads?
They will be back in stock sometime in June.
Thanks for your patience.
The new run has a bit of a change, and it took some time to perfect it.:sssh:
