Typical output of 400 lumens at 1400mA (350mA/die) means about 100 lumens per 350mA for each die... which essentially means that the P7 is just 4 U-bin dies in parallel, in the same package.
I searched for that before posting here, but could not find it. Moderator, please attach to that thread if you want.There's already a discussion in the general LED section
Nah... 10W isn't much... and it's not 10W of heat, it's 10 total watts. I figure LEDs can't be less than 50% efficient, so that's 5W of heat to dissipate.900 Lumens at 10watts? This would require the whole light to be used as a heat sink, would it not? This might be possible to do (maybe 2 or three of 'em) in a thor mod with active cooling (fans). Anyone want to try that?
-Max
Just heatsink the head and fin it a little... should be fine.
