OnlyownEnergizer250lumen
- Joined
- Aug 15, 2015
- Messages
- 660
What materials/LED/components would make the most efficient hand warmer of a flashlight? I know they sell hand warmers, but I want a flashlight to accomplish this purpose around the house and in the winter. It's the only element that my relatives appreciate about my lights. When they say they are cold, I turbo blast a flashlight into a safe direction for 30s, unscrew tail cap, and hand it to them. They smile for about 5 minutes… then they are cold again and I have to repeat the process.
I want a flashlight that gets hot fast and stays hot long, that uses the least amount of battery drain for the greatest production and retention of heat. The heat should be dispersed as equally across the body of the light as possible, not just a burning hot head with a cold body. Lockout mode would be cool, but not necessary.
Questions:
1. What material and why? (Copper, aluminum, titanium, something else?)
2. What size is most efficient? (Compact 18650 with small exterior surface area? Larger pop-can/2 handed light?)
3. Which battery type has the best efficiency/capacity but can also hit max turbo output to heat body faster? (18650? 21700, 26650?)
4. Thick walled or thin walled flashlight chassis?
5. What VN lights do you recommend to accomplish this niche purpose?
I want to charge the light as rarely as possible and get the most hand-warm-uses per charge. I prefer the light to be pocket friendly for travel/EDC use.
Discuss!
Questions:
Discuss!
