Now this might be an interesting discussion.
Imagine a time capsule, which is sealed away for a million years. Within is to be found a elongated cuboid cut out of synthetic sapphire. Embedded within this cube are hundreds, perhaps thousands of tiny images, lasered into the sapphire behind one another in a row and somehow colored. These images can be projected onto a surface using a light focusing mechanism made of a Platinum-iridium alloy with sapphire or fused quartz optics which is already set up and ready to use. Instructions are engraved onto several surfaces and the capsule stored in a secure location, perhaps in orbit or the antarctic, and filled with a inert gas like xenon. It will last for millions of years if undisturbed. The only thing missing is the light source.
There is no telling is a civilization thousands or millions of years from now will have the ability to craft a light source to the exact specifications needed, or if such complex instructions can even be reliably delivered. The most simple solution is to provide the light source needed for the projection. This way however finds it would only have to provide the electricity, which any civilization advanced enough to locate the time capsule to beginn with would be easily capable off.
Now the question is, what possible light source could last such a long time? Even when stored under the most ideal of conditions, I doubt any complex electrical or electronic devices could last for this long.
Perhaps a simple laser is the answer? A mere incandescent bulb? It is simple after all.
What light source could still function after a million years?
