Moved/Relisted: vinhnguyen54 modded lights *9/4 Price Update*
moshow9
El Paso
Sale Terms:
  • US shipping only
  • First Class shipping unless otherwise noted
  • Paypal Purchase of Goods Option (no gift payments please)
  • I reserve the right to refuse sale at my discretion
  • No trades/No Proxy Buying
1) EagTac D25LC2vn SBT90 5700K De-Lens modified by Vinhnguyen54 moved/relisted
2)
Thrunite T10vn II, SBT90 5700L De-Lens modified by Vinhnguyen54 moved/relisted
3) Convoy M2vn Oslon W2 modified by Vinhnguyen54 moved/relisted
4) Mateminco TK01vn NW XHP 50.2 modified by Vinhnguyen54 moved/relisted
5) Oveready Orange Acrylic Camo P60 Host w/P60vn Oslon Square HCRI [Sold to Hnht1030] $200 ships priority
6) Amutorch vg10vn SBT90 5700L De-Lens modified by Vinhnguyen54 moved/relisted
1)
Emitter: Luminus SBT-90. CW Tint with great output and throw for it's size. Uses DriverVN4 Programmable Driver/UI. You may want to re-adjust turbo/timer as I set it quite low since it gets very toasty fast. Includes box, high drain 18650 battery and accessories.
2) Thrunite T10vn II, SBT90 5700L De-Lens modified by Vinhnguyen54
Emitter: Luminus SBT-90. CW Tint with great output for it's size. Uses DriverVNX2 Programmable Driver/UI. Includes box/tin, high drain 14500 battery and accessories.
Emitter: OSRAM OSLON White2 (6500K cool white). This was modified by Vinhnguyen54 @ CPF and direct from him. Strike bezel was heat treated and Vinh added his FS54 forward clicky switch. Uses the programmable VN4 firmware. You may want to re-adjust turbo/timer as I set it quite low since it gets very toasty fast. Includes a high drain 18650 battery, and grip ring. Nice clean and white beam with good throw. Approximately 1000 lumens.
Emitter: Cree XHP 50.2. Tank of a light with a nice 4000K tint and Stock UI (moonlight, low, medium, high, turbo). Includes an 18650 battery spacer, lanyard, protected 21700 Acebeam battery, and box. Full disclosure: The charging connector moved inward for some reason so a standard micro usb will no longer make contact. A 21700 battery can still be charged outside of the light in a charger.
Emitter: OSRAM OSLON Square HCRI (warm white). Host was purchased direct from Oveready, P60vn is a one-off from Vinh. Nice color and throw, beam profile reminds me of a Surefire EDCL1-T. Host is Smaller Diameter Orange Acrylic Camo McClicky - Black MEDpress, Ultra Clear Glass, Smooth Delrin Bezel Ring. Full disclosure: Arrived from Oveready with a crack in the side of the head. It was one of the last ones so I could not exchange it. Comes with a few 18350 batteries.
Emitter: Luminus SBT-90. CW Tint with great output and throw for it's size. Uses DriverVN4 Programmable Driver/UI. You may want to re-adjust turbo/timer as I set it quite low since it gets very toasty fast. Includes 21700 battery.
Amutorch vg10vn SBT90 5700L De-Lens modified by Vinhnguyen54 added.
