degarb
http://www.cree.com/led-components-... Modules/XLamp/Data and Binning/XLampMTG2.pdf
http://www.cutter.com.au/products.php?cat=Cree+MTG-2
I must say I do not understand the lumen/watt, as below. Also, notwithstanding the reasonable viewing angle, probably impossible to get a good beam pattern. But with 5 cells (necklace headlamp, or one 6 volt agm) it should be a very bright with only need of one $3 variable resistor for dimming needed.
Help me understand with these pdf numbers:
6 v 2200ma = 13 wattish
170% of nominal (400 lumen) % = 680 lumens = 52 lumen/watt
or...
.182 ma x 6v 1.09 watts
30h bin (90 cri) : 500 lumen, or greater than 500 l/w (cannot be right) !
or...
