Mule Build?
Chrontius
Orlando, FL
I have a Seoul Hi-CRI diode on a star board gathering dust. Is this all the parts I need to build a mule around it?
http://cl.ly/1w1b0n45270H0E0b3D0S
I'd also like to update my PhotonFanatic Groovy! with a modern sandwich; it's currently got a poorly marked AWR linear dropout regulator with a Luxeon on top, either Lux1 or Lux3, but I can't really tell. Other than sending it off to Milkyspit for a custom XML direct-drive pill, what are my options?
For the mule head:
You will have to remove the emitter from the star and mount it on the Seoul MCPCB
You will need a converter board. Are you using 1 CR123/R123 Boost (BB Nexgen primary cell only) or (GD500 Buck/Boost Converter primary or rechargeable) You choose the output current.
Arctic Alumina Thermal Adhesive (2 Part Epoxy)
wire
I may have some old sandwiches, I can look later.
Sandwich needs:
converter board
emitter board and connectors
LED
We have Luxeon and Seoul P4 LED
