Multi-Led driver?
krazy89
Hey guys...
i got a 3x Cree light that i want to beef up the output of...
2 quick questions...
1. what's the best way to wire them up? should i put the led's in series or parallel?
2. what's a better battery configuration? 2x18650 or 4xrcr123?
Thanks,
KraZy
It's easier to wire 3 crees in series and then use a Shark or fatman to regulate the output. Using 1 li-ion works but a 2/3 li-ions system will be better for the driver (to prevent over heat).
You can also wire them in parallel running one li-ion direct drive. You don't need a driver this way but of course non-regulated. You may also need to use crees with matching Vf for best result. No driver to burn this way.
Or you can use tri-flupic, 8xAMC 7135 for the parallel system.
I personally like running multi-crees in series with Shark. Works very well. Shark is step-up. 2x18650 will be better for 3 crees.
hey Visible...
just wondering where i would get a Shark or fatman?? are they expensive?
the 8xAMC7135 would be cheaper i'm sure...
KraZy
wow... they are expensive!
i remember seeing a mini tutorial on how to connect up like 2 of the 4xAMC7135 boards... maybe that will be a more viable option....
KraZy
hmm... thanks for the info guys..
i was thinking about that P7 board.... with the leds in series... that would mean each led would get 0.93A.... which is good....
however.. the input voltage is 2.7-6.0??? that means i can't use 2x18650.... which is not good.....
what do you guys think about 3 seperate boards 1 for each led? is that efficient??? will that kill the runtimes?
KraZy
3 separate board still have up to 6V input...
With this board you can drive 3 leds in parallel not in series.
hey phantom... u sure tho???
the KD 8xAMC says input voltage to be 2.7-6.0!!
which means that i can't use 2x 18650... cuz that would make it 7.4v in... (8.4V freshly charged...)
the host i have is either 2x18650 or 4xCR123
KraZy
