Megavvolt
Thank you! I just wanted to make sure it's not a malfunction.
Don't they use the same components with similar soldering? How is the quality different?I have even heard it faintly from the higher quality boards like shiningbeams.
Any idea why there's no resistor in the middle of that board? What driver is it? A 2 mode?There is example diagrams for the 12F629 PIC examples, and this one for the Atmel example which is the one in this thread, See also here;
I used my multimeter on the 17 mode version and got 4.7 kHz. http://www.videofoundry.co.nz/ianman/laboratory/research/driverlist.php?price_min=3.6&price_max=3.6Does anyone know what frequency the microprocessor on these boards use to pwm the 7135's Vdd pin?
Maybe someone with a scope could check it?
Hi, I'm newbie building additional light for my motorcycle with a single P7. This mod is really excellent to drive it to 2.8A.However, I'm having trouble with the driver's input Vf(~5v) since my automotive battery supplies 12.0Vf. I appreciate if you could advice me on how to supply just 4.5v-5v to the driver from 12v source by any others means instead of a resistor(i knew, It will be overkill to pass 12w of heat through a resistor).
Many Thanks.
Thanks VidPro for the information.
Driving 3 P7s serially with these drivers are in my plans too but as of now I'm just thinking of 1x P7 which could effectively replace my 35W motorcycle headlamp(I would keep the original too in case of emergency :p) and at the same time I don't want to spend more on this setup.
I was just wondering If it possible to put two or three of these http://www.dealextreme.com/details.dx/sku.26110 in parallel and then PWM with http://www.dealextreme.com/details.dx/sku.6190 after taking those AMCs off.
Further suggestions are welcomed.
Cheers!
Those boards can sort of be run in parallel... but only because they can cope with twice the load anyway. If you have two in parallel, because the drivers aren't perfectly identical one ends up doing most of the work. They use a set resistor to set the current they regulate, and with two drivers in parallel you have two set resistors in parallel, which means half the set resistance, and twice the current they try to provide. It's better to just change the set resistor, add a heatsink if necessary, and check all the other components can cope. (The Schottky diode is an SS24, so 2 amps is fine for it.)I was just wondering If it possible to put two or three of these http://www.dealextreme.com/details.dx/sku.26110 in parallel and then PWM with http://www.dealextreme.com/details.dx/sku.6190 after taking those AMCs off.
If you haven't already bought the Seoul P7, a Cree MC-E would be easier to use because you could drive the four dice in a 2S2P arrangement. That would give you a wider selection of drivers because you could drive each series pair with its own driver (at up to 700 mA).
That would be awesome for redundancy! :) I was actually thinking of just two drivers, though, each driving a couple of dice in series. Those $1.99 ones would do perfectly if they were tweaked down to 700 mA. (That's a 0.36 ohm set resistor, right?)Then in his idea of using many low amp drivers :duh2: , each driver item could be running one of the Emitters in a MCE package too.
hi,
I have some of these drivers.. http://www.dealextreme.com/details.dx/sku.1885.
can i use 3 to drive the ssc P7 bin C or D? the driver is rated at 1050ma x 3 = 3150ma. it is safe?
kong.
