flashlightlens
My 10.75\" TigerLight
There were a four things that always bugged me about my TigerLight.
1) The o-ring that seals the bezel ring to the head of the light. The stock setup on mine had the o-ring squished and exposed. There were many discussions in the past on how some thought they used the wrong size o-ring, or what the purpose of this design was. Frankly, I have no clue why it was designed this way. The more traditional (and reliable, in my opinion) design would be to have the bezel ring cover the o-ring completely as it screwed down. I know that some of the newer 8" designs were supposed to be this way, but I never heard if they made it out the door or not. Here's what mine looks like now:
To do this, I simply cut a notch so an 033 o-ring would snug in right under the bezel.
2) The gold ring...... I underdstand how this might match the fashion stylings of our LEO's and such, but it just not for me. Not to mention the font used to write "TigerLight" on the band. It just wasn't sitting right with me. So I got rid of it.
The head is held onto the barrel by a glue which is apparently commonly used in aircraft assembly. A little heat and some muscle broke it loose pretty easily. The barrel was re-threaded and shortened. I'll seal it back up with an epoxy or adhesive of some sort.
3) All of the modifications to the head assembly pretty much FORCED me to address my third dislike of the original design - The lens setup. Those who have stock TL's with the plastic lens can check me on this. Push on the lens and see if it moves. I could push my lens in quite a bit, therefore breaking any type of water seal it had. This is due to a combination of things - the o-ring issue above, and also the way the lamp assembly sat on a rubber hose (I'll get to that next..). There was a gap between the lens and the top of the head. The only thing keeping it from flopping around was the pressure put on it by the LA. I chose, again, to use a traditional design. I cut a channel in the back of the bezel ring to accomodate an 034 o-ring. NOTE: This setup is specifically sized to use one of my UCL-SI lenses that has a rubber gasket around it.
The o-ring is slightly too large for the application, but with a little love, it fits great and stays put.
4) The sprinkler head mod... The stock rubber hose as a shock isolation system for the LA..... I'm not a fan of it. I think it provides little flexibility and therefore provides little shock isolation. Being that my light was not 1/4" shorter, I had to either trim the rubber hose down, or find an alternative. I looked down from my workbench and saw the answer - sitting in a drawer full of sprinkler parts. A spring. I trimmed about 1.5" off of this one to make it the perfect fit.
The light now has an outstanding water tight seal on the head, the lens is rock solid, the gold band (bling) is gone, and since it's .25" shorter, it fits better in my pocket. /ubbthreads/images/graemlins/grin.gif
