I need a bright light for night mountain biking, and can't bring myself to pay $400 for one. This is my second attempt, and much better than the first, but I am still having problems. I took a 2 D cell maglite, and cut it down to about a one cell light. The reflector fits nice, but I still need to get up the courage to grind off the threads so the cap fits tighter.
I need my switch on the power side of the driver, so I put a plug in the back cap of the light.
Here are my insides. I think I may have created the Frankenstein of heat sinks. I turned it from a 1.5" aluminum rod. My problem is that I have a wood lathe, so it takes forever, and its not exactly precise. I was too cheap to buy multi-colored wire, and unfortunately hooked up my driver backwards. I put the power on the LED side, and hooked the LED to the power side. One little puff of smoke, and it was done.:mecry:I just ordered two more, and bought wire in colors other than yellow. :D I actually used it for a night ride, and hooked it directly to one battery. It ran great for around a half hour before it started to dim. I measured the temp of the heatsink after the ride, and it was only 80 degrees, so I guess a pound or so of aluminum works wonders.
I'm trying to improve the light. My heatsink rattles when I'm riding rough, bumpy terrain, so I'm trying a new idea. I bought a 1.25 aluminum rod. It saves me all the time with the lathe, but it has too much slop. I added a couple grooves, and some O-rings, and its a perfect, airtight fit. I also removed some aluminum to try and get rid of a little weight. I'm a little worried about the O-rings insulating the heatsink from the flashlight body. Is the massive mass of aluminum enough on its own, or should I add a small, tight fitting, to the flashlight body, disc to the front of the heatsink? Also, does anyone know of a good way to mount two of these to a bike?
