LilKevin715
I wasn't sure whether to post this here or the Homemade & Modified lights section of the forum. Mods feel free to move this thread if it is not in the appropriate area.
Many of us guestimate lumen output of flashlights via methods such as a ceiling bounce test. While it does work somewhat it does leave alot to be desired in terms of accuracy. A integrating sphere with a properly calibrated light meter is the definitive way to measuring lumen output, but the cost(s) associated with the sphere itself makes it impractical for 99% of us. A relatively cheap, consistent, and accurate way of measuring lumen output (more accurately relative output) can be done with a lightbox. Here is a quick write up on how I created mine.
First we need a box. I wanted to use a box that was close to a cube shape with a volume of close to a cubic foot. I didn't have any readily available so I chose to use two rectangular boxes with dimensions of 9.75" x 11.5" x 6". The dimensions of the two boxes combined are 9.75" x 11.5" x 12".
Also as seen in the picture above I decided to round off the corner areas to reduce the amount of light that is lost and not reflected. Next up is to apply aluminum foil to in inside of the box with some glue. A thin layer of Elmer's glue-all multi purpose glue (the white stuff) worked just fine. The first purpose of the aluminum foil will be to prevent any external ambient light from entering the box. The second purpose is to help reflect back any light that passes through the diffusion layer (paper) to minimize light losses. Double-sided sticky tape was used to attach the paper to the aluminum foil.
I decided to make the cutout for the flashlight right in the center of the box. The cutout for the light sensor was made in the corner.
Lastly to eliminate any chance of light entering the box via the light sensor hole I sealed off the area with some aluminum foil wrapped with duct tape. The light meter can be easily removed for taking hotspot lux measurements.
I'm still working on fine tuning the design but for the most part the groundwork is finished. Suggestions, feedback, etc. are welcome.:wave:
