Darell
I've had an E2 for a while now, and use it just about every day. Today my first E2e arrived from TTS. Beautiful little thing. I'm still tempted to go get my adjustable wrench to tighten that hex bezel, but I've resisted the temtation so far.
First thing I did with the E2e was to twist it on (duh). Hmmm. Not too impressed. I grabbed my E2 with half-dead batteries and fired it up next to the E2e beam. The older light with older batteries was noticeably brighter. ??? I next swapped the batteries (SF in both cases) and not too surprisingly, the E2e was then brighter with the old batteries than the E2 with the "new" batteries that just came with my E2e. That's a bummer, but at least there's nothing wrong with the E2e that a new set of batteries can't fix. Guess I'll check the voltage on the "new" batteries. What do you suppose I'll discover?
As I twisted the E2e back off, I felt something like a shock go through my thumb. Damn near dropped the light. As I timidly held it with the tips of my thumb and forefinger to turn it off (before it could cause me any more harm
), I realized that my "shock" was actually a tiny sliver of aluminum that had become imbedded in my thumb. Ouch. With the aid of the light held in my mouth, I extracted the sliver and was once again, good to go. In hindsight, I guess I should have cleaned the light off real well before sticking it in my mouth. But no further harm was done, fortunately.
Man, but that little E2e clip is TIGHT. Can anybody actually use that thing? My favorite clip is the "new" E2 clip. VERY nice. Perfect length and amount of "sproing." I'll probably be removing the E2e clip so I can easily carry it in a sheath. Who's got the best sheath idea? I'm not too fond of the SF offering since it only works with a belt. Does Rip-off make one with a clip that fits the E2 well?
I've seen just one other odd thing in regard to the E-series lights. I've had four go through my hands one way or another, and three of the four (regardless of having a LOTC or the standard cap) go to full on mode just barely before the cap is tightened fully against the body. On my current E2, the full on mode begins at least half a twist away from being fully tightened. There is no "feel" for when the light turns on. It is definitely the tailcap that affects this, because I can put that one tailcap on any other light, and the same thing happens. Any clue what might cause that? Easy fix?
Eventually I'd like to have the LOLA in my E2, and a HOLA in the E2e. I'd keep my MNO3's for backups, but it would be somewhat ironic to not have a "stock" bulb in either of my E2's huh? I'd love to be able to choose between carrying a blinding light for security, and a long-lasting light for regular use.
OK, that's it for now from E2 HA land.
