Bolster
Hello CPFers. I'm doing some more work on the Flood Beam Headlamp List 2011 thread. I'm trying to list the Beam Angle for each headlamp listed, many of which are missing. (For some reason manufacturers often omit this measurement, which is an important one to consider when purchasing a floody headlamp.)
I need 2 numbers from you...both are easy to measure and will take you less than 2 minutes:
- Beam Diameter and
- Distance from headlamp to wall
The numbers should be recorded with as much accuracy as possible, although it's often challenging to know exactly where the beam "stops."
I need measurements for the following headlamps:
PT Corona
Irix Icon II - Thanks RonM and Spaulding
Pixa 1 & 3 (probably nobody has these yet)
PT Apex (flood mode)
Petzl Myo RXP (diffused mode)
Energizer Hard Case Pro (flood mode)
RayOVac Sportsman Xtreme 1-AA (flood mode)
Mamut Lucido TR1
Princeton Remix
Black Diamond Storm
Petzl Tikka XP or XP2 (diffused mode) - thank you TurboBB
BlackDiamond Sprinter
(...and any other floody light headlamps I may have overlooked. Any light with both spot and flood, I'm only looking for data on the flood or diffused mode.)
If you own one of the above headlamps, would you please consider taking a moment of your time and sending us distance and diameter so Beam Angle can be calculated?
Many thanks! :twothumbs
- Beam Diameter and
PT Corona
Mamut Lucido TR1
Princeton Remix
Black Diamond Storm
